Patton SN4170 3CX configuration problems
Seorn Thomas
I had a very difficult time programming a Patton SN4170 to work with 3CX version 18
In the end the software on both devices work - it just takes a certain method to get them working
Firstly update Patton firmware - I updated it to the latest version at the time 3.15.9-20061
Release Date 2020/04/29
Program 3CX with Patton gateway E1 - dont select the wrong model ie SN4171 - choose the Patton ISDN E1
In put the just the essential information in the SIP gateway (no need to modify SIP parameters)
Get a Wizard file from the Patton website - its free to signup and log into their portal
When in Patton portal look for Configuration Wizards - particularly the one that is made for 3cx systems
The use the wizard file to program the Patton device and reload.
All credit to the author of the attached wizard file. I tried to make it work by programming manually and failed for hours
GP Concepts
