PBX Express Error in XML file. RequestCode = 'LicenseKey': Invalid reply
qss1
Intermediate Cert.
I have a problem where when restoring a PBX from a backup (in the cloud) using the PBX Express restore to cloud option I get the error
the backup definately has this option ticked, whats going on?
Any ideas?
Many thanks
Can you check that the key you are deploying is the same one in the backup file?
Hi John
Thank you for the reply. when using the PBX express, either I enter a license key and build a new one Or I select restore 3cx in the cloud and I do not see the option to enter a license key.
I checked the license key on the PBX and the license details in PRM are matched when running the restore
Thank you that would explain it, I had not found that article, lets go test that out by re-naming the backup file
Hi John
I have re-run this and have re-named the backup file to all lowercase letters and numbers and id did not make any difference it still came up with the same fault.
I have given up with the restore to cloud option on this and built a new PBX with the license key and restored the backup to the PBX.
Thanks for your help
hughesdouglas
