PBX Express for Backup
swissuser3cx
Dear all,
I am trying to create a new AWS Lightsail instance and to restore the installation from a backup file. According to this post (https://www.3cx.com/blog/docs/cloud-pbx-backup-restore/), it should be possible. However, I wonder where I can find the link to START the whole process. In my account management I am only able to start an installation from scratch. Where exactly can I find the link for the PBX Express Backup installation?
Thanks so much
for now deply the instance on the same license key, once deployed you can restore the backup from the management console. therefore you must connect the PBX to an sFTP FTP or Google Storage account.
If you use the Self Host option you should be able to start like you requested
Cloudstar
