PBX Express not asking for AWS region
Semji - IT
Hello !
I tried 3cx a bit on amazon lightsail with a trial key, took the pbx express, followed the doc, everything running really smooth whether it was deploying or setting up the extensions, groups etc. Now i want to deploy the production instance on AWS Ireland region an not lightsail, following this documentation. I am still using the trial key but we are buying a licence from a reseller, i just don't have it yet and i'm having a problem at step 4 when i choose "Amazon - AWS" as a provider, it doesn't asks me for the region and just assumes ap-northeast-1.
This is the permission policy attached to my user as specified in the doc :
And this is the error message i got
Is there anything wrong in what i did or should i just wait for my fresh licence key ?
Thanks for any help :)
when you are in your AWS console, check in the top right, there is a region selected you currently do the configuration for. Is that set to Ireland?
We only work in Ireland region which is why i wanted to add the instance in the eu-west-1 region. For AMI and Marketplace they are not region specific so it's the global region and it seems i can't select another one. Is this the information you wanted ?
saranga
