- Joined
- May 22, 2009
- Messages
- 75
- Reaction score
- 0
Hi, anyone deployed by PBXexpress to Azure successfully?
I have tried several times and always same result.
1. All starts off ok and creates the images ok in Azure
2. PBX express says "delayed" after 25 mins
3. Even though if says delayed, I can go to the instance that was setup (using the xxx.3cx.com.au domain and username/password that was displayed) and everything works perfectly no issues, I can configure everything, extensions, trunks, make calls, everything is good.......
4. Eventually PBX express comes back and says "failed" (which is strange as it seemed to work)
5. if I close the browser tab running PBXexpress it seems to "delete" the xxx.3cx.com.au domain name so I cant get to the 3CX portal to do anything (Azure config is still there) I assume that it does this as it thinks it failed and backed out some config
so in the end no 3cx instance is working so need to delete the instance in Azure and start again, but get same results.
perhaps PBX express isnt getting a completion message or something, perhaps need a button to say "completed or not" before backing out the config as a work around for when this happens?
