Periodic 100% cpu usage
steve_HR
Greetings,
I have Version 16.0.1.273 3CX hosted trial account. Using Twilio as SIP provider. 2SBC and 7 phones connected
I see 100% CPU usage every hour @30 minutes past the hour. A few days ago it seemed to be happening every 6 hours.
This results in the audio stuttering until after a minute or two. Then when the CPU usage goes back to the usual 4% the audio stops stuttering. I have purged the call history and chat logs, I have not purged the event log.
100% CPU usage occurs even if no calls are taking place.
I'm not sure where to look in the logs or test.
Yep, but I did turn that off a few days ago and it made no difference, just did it again, and it's still at 100%. Will give it a bit of time to settle.
I had to kill the apt-cache and salt-minion processes manually to get it to go down to normal CPU load. I think reloading the container should do the same. As I have shell access to my containers I just killed the affected processes.
Thank you for your feedback, the issue reported is under investigation.
For the time being I would suggest to disable the instance manager on the affected machines, and then reboot to clear any stuck processes while we look further into the matter.
Reactions: AWS2P
Thanks Russell, please do as above for now while we investigate
Hey Gunnar, mine did settle down eventually without killing anything, I guess the service eventually finished doing something, and just wasn't an issue after!
Hi everyone,
Just an update on this. We made a few adjustments to the scripts that are ran in the background by the Instance Manager which should prevent this kind of behavior.
To get the adjustments, all you should need to do is either:
  • Stop the Instance Manager, then start it again
or
  • Restart the whole machine 3CX is running on
(whatever is easier for you)
I think we haven't missed something, but looking forward to any feedback you may have.
We've re-enabled Instance Manager, and I'm afraid the 100% CPU is back...
Have disabled Instance Manager and killed all the (many) apt-cache processes and performance is back to normal again.
Same here, rebooted the server, re-enabled instance manager, CPU back up to 100%.
Going to give it some time to see if it settles.
@RussellPTown @rocketuc
Thanks for the feedback guys! We have updated the scripts and added some reasonable timeouts when some actions take too long (e.g. 10 seconds), after which the delayed process is terminated.
This should counter things like stale apt-cache calls.
Could you try the following?
  1. Turn off Instance Manager
  2. Reboot the server
  3. Turn on Instance Manager
  4. Wait 10-15 minutes
  5. Check CPU usage
The above process should update the Instance Manager scripts. I'd be interested to hear how it goes.
  5. Check CPU usage
Mine has actually settled back down now after the initial spike, rolling along at 1 or 2%.
Reactions: NickD_3CX
[email protected].
