Permission needed to provision own phone (Yealink T Series)?
nobody
Using the current 16.x version, I gave a user the right to login to the management console and to manage his own extension.
Now, when this user make changes to the BLF fields of the phone (T58A), this this will never be sent to the Device unless one clicks in the "phones" menu, then select the phone, and press reprovision. But to do this, either I have to do that manually or I have to give the user the "General system administration" rights.
Or should the reprovisoning happen after waiting for NN hours?
If not, is there a way to create a batch job to run every NN hours that will reprovision all phones?
The phones get provisioned daily, so it will update on its own if you do nothing at all ( no need to setup a job ).
If you want to do it right away, you need to reprovision the phone from your Administrator account.
Thank you for the information. That is what I assumed. But I was told provisioning did not work even after one day. I will try that again myself. At what time is the automatic provsioning done?
it is an interval timer since boot of 24h
(also you reboot the phone...)
bosdorf
