Pharmacy IVR Setting (video desc too)
LeroyToddy12
Trial User
I think 3cx should really add a pharmacy option for an IVR, basically what I mean is we can put records such as name, date of birth, phone number, and medicine name onto the IVR. when you get a new patient, pharmacists can update the custom status of the prescription that we make and we also import audio files of it so it will play, such as, ready for pickup, not ready, ect. what we will do is when we put name and date of birth on the records once we receive a prescribed medication from a doctor/doctors office, users will call the prescription IVR, and you can make your own greeting for it. then it will ask for the date of birth of the patient, the caller types in the date of birth on the keypad using two digits for the month, two digits for the day, and four digits for the year. directions will be played also when asked to put in the date of birth, then it will repeat back to you using the default 3cx voice. for example, "Thats, July 18th 1956, right?". then it will say the name that is on that record using the default 3cx voice, for example, "we will be looking for prescriptions for john smith". then it will look up the records and say the name of the prescription and the status of the prescription using the custom voices of the medication names we imported onto the config. for example, "you have a new prescription called, melatonin that is ready for pickup. Say there is more customers with the same date of birth, how it knows who is who is by using the phone number that the customer called from and the phone number that is programmed into the records so it doesnt get customers mixed up. if they call from a different phone and enter the date of birth that is programmed to a different phone number, it will say, "using the number you are calling from, i have already tried looking you up with no success, can you enter another phone number on the keypad we might have on file? you will use the numbers 1 and 2 to answer the questions asked by the IVR, 1 is yes and 2 is no. please 3cx i beg of you to add this. thank you so much! audio example is included in the link.
You can create this with the Call Flow Designer.
oh nevermind i found it
If you want to collect that as DTMF, you can use the User Input component. If you want the customer to say it, you can use the Voice Input, and do the speech recognition with Google Cloud. In any case, you should provide a way for the user to confirm that the detected date is correct, for example play it back and press 1 to confirm.
so my call flow wont play the full duration of the audio for some reason, are you able to help me on that or is there some type of software that i can use instead that is free and that will do what i want it to do like i explained previously?
What you are asking for can be done with CFD, however it will require interaction with a server to collect and save this information. This would be a complex design and would require someone with knowledge of CFD and database interaction. I can think of only a few people that I know of that can build this out, @ConceptsWeb , @edossantos_sipcaller and myself.
Yes, this is a very complex call flow. If you don't feel confident enough to get it done by yourself, you should contact a third party to do this. I'm not doing this kind of jobs as I'm focused on SIP Caller now, but you can contact @ConceptsWeb, @SnakeRiverWebDevelopment, or @VoIPTools to get this done for you for a fee.
Reactions: N_G and Evolute IT
okay, ill probably find something else. thanks though!
Diogo Maia
