Solved Phone Logos
Ibehere
I have both Fanvil 5S and 5U phones. Neither will show the custom logo on the screen. I have tried using all sorts of variations to make it work. I've followed the specs posted here as well:
https://www.3cx.com/docs/ip-phone-background-logo/
Am I missing something?
Thanks,
Ernst.
Do you have an enterprise license? What version of 3CX?
Yes. We have an enterprise license and our 3CX version is 18.0 Update 3. Its 3CX hosted.
Thanks,
Yes. I confirmed my logo meets those specs
Did you reprovision phone to push it through?
Reactions: VasilisV_3CX
Confirm you're using supported templates with the latest FW?
Firmware is up to date. As for templates. Where can I confirm that?
Is the phone in red when you go to the phones tab?
No. Looks normal.
Hi. So I went through the process. I still cannot get my logo to show but for some reason now the 3CX logo shows. It didn't before.
Also... when logging directly into the phone there is no option to upload/update the phone screen image.
Thanks,
Sounds like the phones are having problems with provisioning.
Since you don't mention your firmware version, make sure you install whatever is on this page specifically:
https://www.3cx.com/support/phone-firmwares/
Then factory reset then phone, and reprovision it.
How exactly are you provisioning them by the way, can you share details?
I was able to work it out. there was something wrong with the image and it seems fanvil phones are super picky about the images.
Thanks,
Reactions: JohnS_3CX
Glad to hear it was resolved Ernst!
dominik.pepel
