Phone losing Dial tone
jake.peters
We have an issue where the phones lose dial tone and can not hear anyone on the other side of the phone, and when rebooting the phone it shows SIP register failed and one phone shows timeout error, we then have to reboot the router and the switch and it brought all the 4 phones back online, however we do not suspect it to be the switch as there were 2 other phones on the connection and they were fine. They are using a Draytek router
If possible, swap out the router. That's about the only way you can be certain that it is not causing the issue. It wouldn't be the first time that a piece of hardware that "shouldn't do that", did.
They have no SBC installed on-site
They have 2 Fanvil X4U-v2, 2 Fanvil X4U and 2 Fanvil X4 if this helps
Okay, we have set that up, will just monitor and Ill update if that has fixed the issue
Appreciate the help
Reactions: JohnS_3CX
Great news, let us know how it goes!
In case you face the same issue, you can look at the Voice & Chat page and check if the X4U-V2 SBCs are green.
Diogo Maia
