Solved Phones go to DND every night and the user has to manually take them out of DND
ZCSFT
I am having an issue where one of our one specific set of phones in one of our 3CX Instances are going into DND every night and the users are having to take them out of DND every morning. I have run into this issue before and so far all my research and troubleshooting hasn't turned up an answer.
Has anyone else run into this?
3CX Environment Info
Version: 16
Phones: Yealink T46S
Firmware: 66.86.0.5
Hi @ZCollins-SFT
Based on your description, I can assume a few things and also suggest a few points to check
a) Your extensions have Autoswitch enabled, under their Forwarding Rules (this is necessary for them to go to DND automatically)
b) You might also have office hours override under each specific extension (under the Configure button) and this will ignore your Global Office Hours
c) You have Global Office Hours setup, but they are not set up correctly (ie. the opening hours are not at the correct time). Found under Settings
d) Possibly, the system has the wrong time, and even though you might have all the above setup correctly, it does not make the extensions available
e) If you are using custom / outdated phone templates, they phones are not switching back to available when the PBX tells them to.
I think this should be enough to get you started, please investigate the points above and let us know if this helps you or if you find anything additional you want to share
PS: You are on V16 - I very highly recommend to upgrade to V18 as soon as possible as your current version is close to end of life. Read this blog post to get informed about what will change: https://www.3cx.com/blog/news/v16-web-meeting-eol/
Hi @ZCollins-SFT
Hello @JohnS_3CX,
I will take a look at these and let you know!
Thanks!
Hi @ZCollins-SFT
Hello @JohnS_3CX
It was the Auto Switch! I didn't realize that was a thing, its schedule was different from the Inbound Rule schedule which caused the issue.
Thanks!
You are welcome, I'm glad to hear you found it :)
Reactions: ZCSFT
Finatra.us
