Pi SBC Licensing error
DylanB
Platinum Partner
Hi People
I am trying to setup a Raspberry Pi 4 as a SBC.
I have reloaded the Raspbian OS multiple times and ruled the OS of the Pi out as a potential problem.
When I run the "wget https://downloads-global.3cx.com/downloads/misc/d10pi.zip; sudo bash d10pi.zip" command on the Pi the correct page pops up with the 2 options that are:
"1. 3CX"
"2. 3CX SBC"
I then press 2 and continue with the instillation.
The prompts of the PBX details are then entered and I receive this error:
"Unable to reach 3CX Sever at
https://.................com
Please double check "3CX Provisioning URL" value and
confirm that the SBC Trunk is created properly from within
your 3CX management Console.
Also 3CX must have a valid secure SSL Certificate so if
you have a custom certificate which has expired or not
renewed, the installation will fail."
I have made sure that the license is renewed and up to date.
The URL is correct because it was copied from the 3CX website.
The Pi runs and works as a SBC with a different PBX.
I am unsure if the Pi is giving this error because the PBX I want to set it u with has a wildcard certificate or if there is some sort of other problem?
Hi People
"1. 3CX"
"2. 3CX SBC"
What URL did you enter? Had your created the SBC entry in 3CX?
Reactions: ChrisC_3CX
Since you're using a custom FQDN do bear in mind that you might need to import the certificate on the Pi's OS level too.
EDIT:
What do you get if you run:
Code:
wget https://<FQDN>:<HTTPS_PORT>
EDIT:
Code:
bash: syntax error near unexpected token `newline'
Where <FQDN> put your own FQDN (e g mydomain.3cx.com) and where <HTTPS_PORT> put the port you configured for HTTPS (e g 443 or 5001).
For instance:
Code:
wget https://mydomain.3cx.com:443
For instance:
Code:
"GnuTLS: The TLS connection was non-properly terminated.
Unable to establish SSL connection."
I'll PM you for more information on this.
Does your SSL cert contain the intermediate certificate?
Customers who are using custom domain must ensure:
  1. A valid certificate covering the installations FQDN as per common certificate validation rules. Wild cards can be used, however, wild card certificates cannot be re-used for secure SIP transport as per RFC later.
  2. Necessary "Intermediate-Certificates" must be included in the Nginx web server certificate. Follow the guidelines of your certificate issuer. Generally, all certificate issuers rely on intermediate certificates. You can test your setup here: https://www.sslshopper.com/ssl-checker.html
@SweetAction is the answer. Beat my head against the wall on this one. Most things worked fine after I replaced my FQDN cert and I forgot that intermediate. Random things wouldn't work. SBC provisioning, pushing some updates to phones.
WagnerFT
