PI SBC settings change
AWS2P
Hi ,
is there a way to change Pi SBC settings to reuse it on another site with another PBX?
no need to purge before ?
it's working the same even if PI is 3B+ or 4?
Reactions: AWS2P
does this also give access to change Local IP , host name, and port used for the PI or is it needed to edit other config file or do this from PI login ?
The setup only changes the config, hostname IP and anything else need to be done from the command line or desktop if you have access, we use teamviewer to remote into all of our SBC, this way we can also admin the phones as well.
So you add teamviewer to SBC config? is this 3cx supported .?
How do you do this teamviewer install and settings?
On every new PI we get, I install teamviewer before I install any thing else. We then ship the out to the client, once on site I install 3cx, and then set ip from dhcp to static. to install teamviewer form the PI desktop google teamviewer fo PI, it can also be done via command line.
Do you load and use PI SBC through GUI or only CLI
Well it seem to be something really painfull to get it installed on pi
on which pi are we speaking 3B+ or 4 ? Deb 9 or 10? which TV release do you install ? lots of posts are with problems during install after TV 12 ?
Already have a teamviewer licence, no problem
PI3 and always Deb9?
Yes, I have an image i downloaded, I use the same image then make sure to run updates before deployment
I found this command on TV website, do you install like this ?
No, but I am sure i can if needed. I put a monitor keyboard and mouse on the pi for first install,
Ok thanks , and after is it easy to link the PI to your TV account as it stay always available ?
You will need to set a password for it, but after that I can connect as long as it is online, at the time of install I also install a lable with the TV Partner ID, that way If I cant find what goes to who, all I do is ask the user to give me the number on the top.
Well done;)
[email protected].
