PI4 Install Error?
KOTB
I ran the install string a few times but it keeps failing on me?
enough space on SDHC ?
No failure on memory card ?
did you used 3CX iso to install?
Did you follow the information in this document https://www.3cx.com/docs/installing-pbx-raspberry-pi/
Maybe worth starting from scratch and post the errors on the initial setup
Does the spec of your PI meet the minimal spec - 4mb or 8mb version and 32 gb+ card
Yes, I got a P4 8GB RAM and 32GB SD card 80% of it is FREE. Check my text file
I ran it twice and I got the same error
Thank You!
Pi-Hole is the problem. There should be nothing else on the Pi except 3CX.
Another application is using port 80, as above nothing else should be running on the PI except 3cx
I got the Pi-Hole web admin port changed now and I finally got 3CX installed and running but I can't logon!? I rest the password and with the new password I still can't logon. I wait a few hours and I still can't logon
"Login access denied. Too many incorrect login attempts. Try later or contact the Administrator."
Thank You!
Sounds like your IP is blacklisted. Manually change your IP or try from another computer.
Reactions: KOTB
Finally, THANKS!!!!
hpgitsupport
