PIN then press pound
James Dyke
I have set the UK prompt set but its still asking for "pound"?
also sometimes the VM answer's but the announcement ist played?
James.
OK, so i figured i need to change the prompts in the extension. good job its only 10 :)
but on this phone i still don't get VM correctly all the time.
hi, not working on the default?
Hi, double checked, its 8000 as needed, uploaded again and still nothing.
Just to clarify, are you using the default voicemail prompts or have you recorded custom ones?
Ive not had to change it on a per extension basis and Dorothy says hash for me.
You got your active prompt set to UK English from settings > system prompts?
You have a Dorothy in 3CX box ? :)
yes UK, and i had to set in each extension.
Did you tick all and bulk edit or edit one by one?
If you make a new ext does it go to UK by default?
it may be that when you first set up the PBX your default prompts was set to US. Therefore, any EXT you made picked that up.
[email protected].
