Playing with VPN - Incoming call rejected
I've gone through the forum threads related to this error but haven't had any luck so far.
As a proof of concept, I am playing around with VPN connections to cloud hosted 3CX.
We have the following setup:
- 3CX Ent v16 U6 Debian Linux VM hosted in the cloud with a public IP, as well as internal 10.10.1.1 address.
- Sonicwall Tz500 behind primary router (double NAT) at client side, with 10.10.2.0 internal LAN.
- Yealink T53w as a test phone.
After 3CX was configured, we added eth1 with 10.10.1.1, restarted the VM and installed Strongswan.
We successfully built the VPN using Strongswan and Sonicwall's built-in IKEv2 IPSec VPN. We can ping both ways etc.
I provisioned the T53w as a local device (10.10.2.174), connecting to 10.10.1.1 and provisioned successfully.
However, all call attempts fail with the "Incoming call rejected" entry in the log - see below. I can't even call voicemail as a test.
I have verified that all internal subnets are included in Parameters - LOCALSUBNETS:
10.0.0.0/8,169.254.0.0/16,172.16.0.0/12,192.168.0.0/16
Any thoughts?
10/29/2020 12:43:53 PM - [CM503013]: Call(C:6): Incoming call rejected, caller is unknown; msg=Invite-IN Recv Req INVITE from 10.10.2.174:5060 tid=2632460564 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.174:5060;branch=z9hG4bK2632460564
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>
From: "Nowak 604 Test"<sip:[email protected]:5060>;tag=446441746
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
Content-Type: application/sdp
Proxy-Authorization: Digest username="wK4QQ10lV7",realm="3CXPhoneSystem",nonce="414d53595f9b1b7936:21895c922d2df1d041d4ece6f1ee5e29",uri="sip:[email protected]:5060",response="088e077db2a319bdc0cf40f51fa8be83",algorithm=MD5
Supported: replaces
User-Agent: Yealink SIP-T53W 96.85.0.5 805ec080628a
Allow-Events: talk, hold, conference, refer, check-sync
Content-Length: 304
v=0
o=- 20003 20003 IN IP4 10.10.2.174
s=SDP data
c=IN IP4 10.10.2.174
t=0 0
m=audio 12604 RTP/AVP 0 8 9 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
a=sendrecv
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
I was able to find a solution for this. Even though they are local IPs through the VPN I had to enable the setting to allow direct SIP calls and change the FQDN to the 3CX VPN adapter's IP (10.10.1.1).
In Settings - Network - FQDN
I'm not sure why LOCALSUBNETS parameter didn't allow this IP range, but maybe it's not designed for that.
Cloudstar
