Playlists
Sean Glasspool
Hi Community.
Trying to get a bunch of audio files to play in order (or at least upload in order)
Tried many variations, however each time I try to upload in order, 3CX seems to re-order like this.
I think the only way forward is to join the files...........
Hello @Sean Glasspool
I did try to replicate the issue but my files stayed in the correct order. Are your files rearranged always the same way or is the order random?
Hi @YiannisH_3CX
So if you click Save, return to the Playlist, is it still in order?
Sean
Unzip the Video and play in VLC / Film & TV in Win10
I see what you mean and i will try to replicate the issue on a different machine to see what is causing this. On mine files stay in order even if i save them and go back to the playlist.
jmarshall
