"Please enter your remote access code" What this?
shivanuo
Im seeing this system msg been play to some people calling in, but im not sure what are the conditions for this to happen. Im just using a simple ATA/SIP to IVR to Ring Group setup.
Maybe if all extensions on the ring group is busy?
When i first trying 3CX i used queues, and i had this same msg been show always after 1 minute in queue and the call is terminated after that.
Do you have anything going to ext. 700?
Yes it is the main ring group, it was used for something else i dont remember exactly what now, that i had to change or delete in order to create a ring group with ext 700. I did this because i was migrating from another pbx system and i did not wanted to change extension numbers.
Should i change the ring group to other number?
That is the reason you're having a problem.
Ext 700 is the dial-in extension (by default) for teleconferencing.
Easier to change the ring group extension.
There are some system extensions created by 3cx - conference system 700
As above change the extension number , you should not be able to create any extension. Groups, Ivr that conflicts with the system extensions
I see. Strange that i was able to delete the system extension, use it for something else and still has system stuff working on it, i think i should report this.
Thanks. ill change the ring group to something else.
EDIT: To be precise i changed conference to 900, this is why i was able to create a ring group on 700.
Hi @shivanuo
Are you sure this message is actually played from the 3CX system? I quickly looked through our prompts and there doesn't seem to be such a message.
fcentral
