PMS integration with 3cx
Song
My PMS is asking this:
Typically there is a prefix that needs to be entered before the code, your PBX vendor should be able to confirm this if you are unsure - it is usually like *68 or *2 - followed by the actual code that updates the status and is hard coded via Comtrol. You may want the hotel to test the codes out.
1 = Dirty
2 = Clean
7 = Pick Up
8 = Inspected
Any prefix for 3cx? please advise..
Default prefix is *68. You can check or change the prefix in Admin, System, Dial Codes (listed as Maid Codes)
thank you for this. i'll test it out with the PMS..
This is also clarified in the guideline here.
Reactions: KyriacosS_3CX
circusduck
