PolyCom Soundstation Duo
ScottWalker
I've been searching but not having much luck finding out how I can "provision" soundstation duos in 3CX.
They currently are all setup and working but are listed as unprovisioned. Is there a way to fix this?
I don't see the Soundstation Duo as a supported device so it doesn't surprise me you can't find any information on it. Sounds like you manually configured them and they are working so that's as far as you are going to get.
Hello @ScottWalker
Please note that since this is not a supported device it cannot be provisioned so it will appear as up-provisioned in the management console.
GemmaC
