Polycom SoundStation provisioning template for SBC
smarti
Has anyone written their own provisioning template for a Polycom IP5000 or IP7000 that works with an SBC?
I've added a custom template based on the existing Polycom template with reasonable success. But cannot get the directory download working correctly yet.
I've found that the latest firmware fixes the https provisioning file issue so it mostly seems to work - I'm currently testing all the options to double check.
However, if someone has already done this then it would save me a lot of time!
TIA!
it is not so much to enable SBC, but I am not aware that those devices trust Let's Encrypt Root Certificates and there will fail to provision...
Not quite sure what I did, but the directory is loading now.
However:
reg.1.address
reg.1.auth.password
reg.1.auth.userId
reg.1.label
reg.1.displayName
Aren't being loaded, but...
reg.1.server.1.address
reg.1.server.1.port
reg.1.outboundProxy.address
reg.1.outboundProxy.port
are getting loaded absolutely fine. They're all in the same <reg> ... </reg> element so it's a bit of mystery to me.
Slight error in my previous post.
Only
reg.1.address
reg.1.label
reg.1.displayName
are being ignored by the phone.
Final update - it all works fine now.
I factory reset the phone and reprovisioned.
Wecare_ITA
