port 5060 exclusivity
zetronuser
New User
When I run the Max-D Console app (this is our Dispatch SW with Telephony Gateway that's trying to talk 3cx) on the same machine where the 3cx PBX instance is hosted and then run the ‘Firewall Check’ utility, I get slightly different port-mapping errors…indicating that port 5060 has a conflict due to it also being used by the ConsoleAudioApp (see attached screenshot). Does port 5060 need to be set for exclusive use by 3cx?
Thanks.
Only one application can listen on a port at the same time. (Aside from a reverse proxy etc)
Thank you, Steve! That makes sense. We will make sure we don't run our Console app on the same machine where 3cx PBX is installed.
Note that any 3rd party installation on the PBX server can cause such issues and should be avoided.
awan05
