Possible to Ignore Forwarding for specific Ext.
tKay
Hi!
Is it possible to set an Extension who can call everytime (also if the destination forward it's calls)?
I would need this for an Assistant who should be allowed to call his boss (who don't want to be called by anybody else).
Would be great if you can help me.
Thanks, tKay
Reactions: Jonas Zürcher
Hello @tKay
The only way i can think this would be possible is by assigning the boss a second extension number that only the assistant knows which can be called at all times. You can also add exceptions on the second extension that only allows the assistant extension to call him by blocking everyone else.
Alternatively you can create a feature request in our ideas section of the forum where it can be upvoted by other users and evaluated by the appropriate department.
aatroxadrian
