- Joined
- Jul 20, 2020
- Messages
- 77
- Reaction score
- 7
Hi Thank you for your support.
Now, this is a question about the integration of 3CX with zoho CRM.
When you use 3CX with pre-fix operation by multiple outbound phone numbers, what are the proper steps of click-call from zoho CRM via 3CX?
And every time a new contact is created from an incoming call, is it needed to manually add respective pre-fix?
I'd appreciate the recommended operation of zoho-3CX integrated system when pre-fix are used.
Best regards,
Hiro
Best regards,
Hiro
