- Joined
- May 28, 2018
- Messages
- 3
- Reaction score
- 2
We are moving a client to a 3CX system from a mix of other systems - some that used 3 digit dialing, 4 digit, or 5 digit and consolidating to a 4-digit extension 3CX.
Wondering if I can help users who forget the new 4-digit system and dial a 3 digit number (or 5 digit) and fix it to dial the correct 4 digit number.
All former 3 digit numbers are in the new system with a 5 added as the first digit. i.e. x221 in old system becomes x5221 in the 3CX.
If someone forgets, and dials 221, I am wondering if I can prepend the 5 automatically to convert it to 5221 for processing.
I tried using Outbound Rules - if 3 digits dialed by anyone in the default group, strip 0 and prepend 5.
- However, the call just fails
- I tried with both a valid Trunk as first option as well as Block - but either way, it wont treat it as an internal extension
- I guess the rules literally only work for Outbound calls, not internal extensions
Hopefully I am explaining this OK...
Any thoughts? Not critical, just nice to throw in there if I can do it.
