Prevent UK Mobile (other) Calls
Den1s
It appears that the calls below are very costly when calling compared to normal mobile phone calls. How do i tell my £CX 15.5 Standard Edition to disallow calls to these numbers?
All numbers starting with the following digits belong to United Kingdom (others) (Mobile):
074060, 074061, 074062, 074063, 074064, 074065, 074066, 074067, 074068, 074069, 074080, 074081, 074082, 074088, 074089, 074171, 074172, 074176, 074177, 074178, 074179, 074180, 074181, 074182, 074183, 074184, 074185, 074186, 074187, 074188, 074189, 074390, 074391, 074408, 074409, 074410, 074411, 074412, 074413, 074414, 074415, 074416, 074417, 074418, 074419, 074510, 074511, 074512, 074513, 074514, 074515, 074516, 074517, 074518, 074519, 074520, 074521, 074522, 074523, 074570, 074571, 074572, 074573, 074574, 074575, 074576, 074577, 074578, 074579, 07464, 074650, 074651, 075090, 075091, 075092, 075093, 075094, 075095, 075096, 075097, 075200, 075201, 075202, 075203, 075204, 075205, 075206, 075207, 075208, 075209, 075370, 075371, 075373, 075375, 075376, 075377, 075378, 075379, 075590, 075591, 075592, 075593, 075594, 075595, 075596, 075597, 075598, 075599, 075710, 075718, 075890, 075891, 075892, 075893, 075894, 075895, 075896, 075897, 075898, 075899, 077000, 077001, 077003, 077007, 077008, 077442, 077443, 077444, 077445, 077446, 077447, 077448, 077449, 077552, 077553, 077554, 077555, 07777, 07781, 077977, 077978, 077979, 078220, 078221, 078222, 078224, 078225, 078226, 078227, 078228, 078229, 078297, 078298, 078299, 078391, 078392, 078397, 078398, 078644, 078722, 078727, 078730, 078744, 078745, 078920, 078921, 078922, 078925, 078930, 078931, 078933, 078938, 078939, 079110, 079111, 079112, 079117, 079118, 079240, 079241, 079242, 079243, 079244, 079245, 079246, 079247, 079248, 079249, 07937, 079780, 079781, 079782, 079783, 079784, 079785, 079786, 079787, 079788, 079789
outbound rules...
provider could possibly block it...
where is your location?
If there is a pattern to the numbers, could can create fewer rules to intercept the calls (block them). So, as one example) you could have a rule...numbers starting with 079, or 0792, or 07924, that is placed before the "general" catch-all rule for most calls. The more digits, the more specific the rule. Those calls could then be blocked. It becomes a lot more complicated (more rules) when :allowed prefixes are "mixed in" with the disallowed ones.
As Craig mentioned, some providers allow you to a the maximum per minute call cost. So if most calls were under , say 2 pence a minute, then set the maximum at 3 or 4, thus blocking calls to a high tariff number. This may have the added advantage of your provider playing a message better explaining why the call did not go through.
fransisco
