Solved Problem when setting up a Pi
Alphabetic
3CX MVP
Hi support
trying to install SBC on a Pi.
Installing the OS is fine but when running the cmd to install it and then typing the Auth key I get the following error:
Code:
wget https://downloads-global.3cx.com/downloads/misc/d10pi.zip; sudo bash d10pi.zip
--2021-11-08 16:23:41--  https://downloads-global.3cx.com/downloads/misc/d10pi.zip
Resolving downloads-global.3cx.com (downloads-global.3cx.com)... 104.20.78.239, 104.20.79.239, 2606:4700:10::6814:4eef, ...
Connecting to downloads-global.3cx.com (downloads-global.3cx.com)|104.20.78.239|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2856 (2.8K) [application/zip]
Saving to: ‘d10pi.zip’
d10pi.zip           100%[===================>]   2.79K  --.-KB/s    in 0s
2021-11-08 16:23:41 (14.8 MB/s) - ‘d10pi.zip’ saved [2856/2856]
--2021-11-08 16:23:41--  http://downloads-global.3cx.com/downloads/3cxpbx/public.key
Resolving downloads-global.3cx.com (downloads-global.3cx.com)... 104.20.79.239, 104.20.78.239, 2606:4700:10::6814:4fef, ...
Connecting to downloads-global.3cx.com (downloads-global.3cx.com)|104.20.79.239|:80... connected.
Length: 1179 (1.2K) [application/octet-stream]
Saving to: ‘STDOUT’
-                   100%[===================>]   1.15K  --.-KB/s    in 0s
2021-11-08 16:23:41 (41.6 MB/s) - written to stdout [1179/1179]
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
OK
deb http://downloads-global.3cx.com/downloads/debian bullseye main
deb [arch=armhf] http://downloads-global.3cx.com/downloads/debian bullseye-testing main
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Ign:2 http://downloads-global.3cx.com/downloads/debian bullseye-testing InRelease
Ign:3 http://downloads-global.3cx.com/downloads/debian bullseye InRelease
Err:4 http://downloads-global.3cx.com/downloads/debian bullseye-testing Release
  404  Not Found [IP: 104.20.78.239 80]
Err:5 http://downloads-global.3cx.com/downloads/debian bullseye Release
Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Get:7 http://archive.raspberrypi.org/debian bullseye InRelease [23.5 kB]
Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [200 kB]
Reading package lists... Done
E: The repository 'http://downloads-global.3cx.com/downloads/debian bullseye-testing Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://downloads-global.3cx.com/downloads/debian bullseye Release' does not have a Release file.
N: Repository 'http://archive.raspberrypi.org/debian bullseye InRelease' changed its 'Suite' value from 'unstable' to 'stable'
OK
connecting https://FQDN.3cx.co.uk:5001
Ign:1 http://downloads-global.3cx.com/downloads/debian bullseye InRelease
Err:2 http://downloads-global.3cx.com/downloads/debian bullseye Release
  404  Not Found [IP: 104.20.79.239 80]
error: Cannot install the 3cxsbc package
Why is it trying to download Debian 11?
I've the same problem on Rpi 4 with a fresh image "2021-10-30-raspios-bullseye-armhf-lite".
found the problem: following the official guide on the site for installation on raspberry, clicking on the download link of the raspbian lite image you download the latest version which is based on Debian 11 Bullseye.
You need to download the previous release, based on Debian 10 Buster, and the installation proceeds without problems.
Reactions: Wesley Telecomlijn
I edited the link I had posted above, it will have the most recent version of Buster now.
The same link will appear in our guide shortly.
Is that why the community forum went down for a bit? :p
apbGroup
