Problem with "Limit Call Pickup to Extension Group"
hubi777
Under Settings - PBX Settings , have you ticked 'Limit Call Pickup to calls received in their extension group'
Yes, but it will only work if “show calls to group member” is activated (contrary to the documentation).
Hello @hubi777
Please note that the Rights mentioned in the guide must be enabled for the extension picking the call up. But in order to be able to pick up a call, the extension must be able to "see" the call. If the extension ringing is not publishing the call to other extensions then *20* has nothing to pick up.
WagnerFT
