Solved Problem with transcription
Flavien
We are using 3CX V20 Update 9 (Build 995, AI Edition 16AS, hosted by 3CX) and are experiencing an issue with call recording transcription.
Our configuration:
  • Transcription provider: 3CX Transcription Service (Cloud)
  • Language: French
  • Extension / department / queue settings: "Voicemail & Recordings"
  • Call recording: enabled, all calls
Voicemail transcription works perfectly.
However, call recording transcription produces nothing, no transcript, no error, no event in the logs. When I click "Transcribe" on a recording nothing happens.
Via the event log, I have no log related to transcription.
Is this normal or is there a way to fix this? Is it mandatory to use a third-party provider (Grok, OpenAI, Google)?
Thank you in advance for your feedback
Please note that the 3CX Transcription Cloud service is not included with the 3CX AI Subscription. Additionally, the older ENT+ licensing model, where transcription was available as a feature, is no longer offered.
You can therefore choose to use an alternative transcription provider, such as:
  • Google
  • OpenAI
  • Grok (available from Update 9)
Alternatively, you may install and use the 3CX Self-Hosted Transcription Server if you prefer to keep transcription services on your own infrastructure.
Please let us know if you require any further information regarding the available transcription options.
Reactions: KyriacosS_3CX
HI,
Thank you for your feedback and the clarifications.
Reactions: Charles_3CX
amazingbv
