Promoting a Generic provider to a Supported one
Paul Reynolds
Platinum Partner
We have a lot of trunks that were set up with a particular provider BEFORE they were added to the Supported list.
They were setup as Generic VoIP and as such have the deadly red ! on the dashboard.
Is there any way to adjust the system so 3CX recognises it as a Supported provider WITHOUT deleting the old, adding a new, and rebuilding all of the DIDs, inbound rules, outbound rules etc etc?
I'm afraid you need to do steps you wrote :(
Reactions: Paul Reynolds
Looks like the tick is staying red then because no way is a green one worth that much effort!
Hi Paul,
You can leave it as is, not a problem. Make sure it is aligned with our official template of that provider though, especially in case you have issues. To do that, just create a fake trunk using the official template, and compare all the options one by one side to side (you can open 2 tabs to the management console)
3K8iMGWviZ
