Provisioning defaults?
noord
I have been ‘frustrated’ with this for a while now and I haven’t found a good solution yet, so it‘s time to ask here :)
When setting up a new phone, you can select some things in the Management Console, for example time/date-format, blind or attended transfer, phone language, codecs and a few things more.
Is it possible at all to change the default settings for new phones?
I need to manually change this for every new phone I add. Of course I know custom templates, but they have many disadvantages so I try to keep away from them as far as possible.
Simply answer is no, the 3cx templates will only modify the settings in the template.
If you modify a settings manually via the phone gui, and the 3cx template does not reference this settings - the settings will not change.
The other option is custom templates, which are not supported by 3cx
Perhaps I did not explain correctly what I meant. Or I don't fully understand your answer correctly.
There are some phone settings that are available in the 3CX Gui; the default templates are modified 'on the fly' with those settings, for example, the language of the phone or the codecs used.
But as it is, I need to manually select these options I want for each and every new phone I provision.
It would be useful if I could set-up default values somehow
I understand your question now
The system does not have the function of default settings for new phones,
Stephan Eusebe
