Provisioning Phone
Heardy
Afternoon
Firstly sorry if this a really obvious answer but i'm learning my way around but how do i go about provisioning the system ? Ive been updating the contact numbers BLF so unsure how to do this, i understand that it may do this automatically at some point but want to do it sooner.
I'm at home so not on the local network (If that makes any difference)
Jason
What do you mean ? provisioning is the way to easily set phones with PBX sending parameters to 3CX supported phones.
Provisioning do nothing on system, if "system" is the PBX ?
When you are in console BLF are set in each exension, for example here BLF from extension 106
when done, to apply on the phone you need to reprovision the phone , this is done from phones like previous extension 106
Reprovision is not always applyied in 1s after you click on reprovision and obviously for remote phones
I'm trying to push the numbers programmed to the phone Or is this not necessary ?
Once again sorry if its something really simple and im over complicating it
You can't force it via the Webclient. The phone will reprovision every 24h so the changes will apply themselves.
To force it, click Reprovision in the Management Console, or reboot your phone, it should reprovision on bootup.
The above will only work, if you provisioned the phones via 3cx and the phone is using the 3cx provisioning url
Wecare_ITA
