Public certificate revoked, cannot visit console, how can i update my public certificate
ajwang
as titled, i used to visit my console at https://host.domain.com:5001; however, the cert was revoked, i forgot to renew it, so all browsers forbid console access. what should i do now to retain console access
Are you using a custom FQDN or a 3CX one?
Ideally you would renew the certificate, though if this is not possible right now, you should still be able to access the Management Console even with an expired certificate. If the FQDN does not resolve to the correct IP, you could just use the IP to reach it.
Tech_Support
