- Joined
- Jan 18, 2011
- Messages
- 175
- Reaction score
- 52
Hi, am trying to figure out how to do this and hoping to get a bit of guidance / suggestion.
specific detail for my setup:
I am using latest 3cx - Version 20.0 Update 10 (Build 1694 Beta - AI 1.6.63)
I am working with Voip.MS for my sip trunk for inbound and outbound calling
I know already VoipMS easily allow me to do "Masquerade" outbound callerID if I have validated the masquerade number.
As I write this I realize maybe I have already answered my question. Sigh. I think the baseline security measures at VoipMS maybe will simply not allow me to pass "original caller ID" if that idffers from a validated CID# or a DID linked on my account.
digging into the support forum - I found people talking on this topic in the last few yeasr / older releases of 3cx / but no specific recent discussion
other than 'First be certain what your sip trunk provider allows, if they do not allow, then you are done"
So I think my next step after this 3cx forum post will be a query to tech support @ VoipMS.
anyhow ASSUMING it was possible to do this correctly with VoipMS. And not 'blocked'
I am hoping to confirm (precisely?) on how-where in 3cx to make config change.
The GoogleAI tells me when I asked,
"• Go to 3CX Admin Console > SIP Trunks > select your trunk > Outbound Parameters.
• Locate From: User Part and change its value to OriginatorCallerId"
this sounds pretty good, except that config place does not exist in 3cx currently
and when I dig in the forum with some searches <> I now find discussion on v20 requires to edit this parameter I must (export my template for SIP provider, edit the parameter, re-import the template" as the way to do this.
so any comment (ie "yes that is right" or "no, wrong, do this instead..." would be most welcome.
So. I will update my thread when I have a bit more info back from VoipMS team / in case this thread will be found by others in future and good-to-know reference
thank you,
Tim
thank you,
Tim
