Solved Question about +1 converting to 00
SnakeRiverWebDevelopment
Forum User
With all the changes made I can't find the setting that manages the +1 calling. In the contact list the contacts are saved with +1, when using the webclient to make call to a contact, it dials 00 in place of the +1, how do I change this to just dial just the 10 digit number? I made a outbound rule that strips out 00, but I am sure i am missing the setting
ProductEnterprise Annual
Version Number18.0 (Build 901)
Foot note in the system dropdown the PBX that is having the issue is not listed.
in your webclient navigate to settings -> audio/video and click the box next to "replace + with"
Reactions: jed
Got it!, Thanks. :)
mazet
