Question about changing provisioning link
jmatano
Platinum Partner
Last night we switched our 1024SC system from Windows Server to the official 3CX Debian build with a restore. The one issue that came up, that we have never seen from a Windows to Windows restore is the provisioning folder value change. Before I change the provisioning folder value back to our old version, I want to make sure that it is acceptable and will not cause any system issues.
We have over 1000 phones on our hotdesk system. Manually updating the provisioning link for all those phones would be extremely tedius.
To be clear, I want to update the parameter PROVISIONING_FOLDER to our previously value, which has been in place for the past 3+ years.
Thank you in advance for the feedback.
Be sure to put a ticket in if you haven't already. I can't say that I've changed the provisioning path before but I don't see it being an issue.
Reactions: jmatano
Just an update. Switching the parameter worked. I copied down the new provisioning folder address to make a backup. Made a copy of the folder on the server and renamed it to the old parameter. Restarted Nginx. Worked perfectly. Just in case for anyone else wondering.
Reactions: NikosT_3CX
SupportRock
