Queue Callback CallerID
pa_an_br
I'm trying to specify the outbound callerID for a callback of a queue, i need to change it to a UK NGN number not the DDI Attached to the Queue.
I've google'd and searched the forum with no joy and i can't find anywhere in the system an option to specify it.
Thanks in Advance
You cannot set a DDI but you can specify a trunk to use.
For example:
Reactions: pa_an_br
Thanks for that, better understanding now.
Do you know of a workaround i could implement to get it to show a different CallerID, I need it to be 0345XXXXXXX instead of the Main Trunk number.
I think you might be able to use CFD for that but i've never used it so i'm not entirely sure. Hopefully someone else can answer that question.
Reactions: pa_an_br
That may depend on your trunk provider. If the trunk is used for other calls as well, and normally shows a "main" number, if no DID number is sent, then you may be out of luck. However, your provider may allow you to establish a second trunk group, as a sub-account, that could be assigned a new, fixed, number. Again, it all depends on what your provider allows.
It doesn't hurt to ask.
Reactions: pa_an_br
Thought that just before your reply lol, have put a call into them. Thanks
Is there anyone from 3cx that can advise or would i need to raise a support call?
hughesdouglas
