Queue or Group Number as CLID internally
pa_an_br
Is this ever going to be a feature we can use, its the only feature i really need that i used to have with FreePBX and i desperately need it.
You mean having calls show the Q number/RG as caller ID?
You can do something similar with the Append/Prepend Q/RG Name.
@ConceptsWeb Yeah, Management want calls to be advertised as the group/queue number so that staff don't ring individuals back.
Any Staff able to add this to Feature Requests? I'm sure I'm not the only one that would love this?
You can make the queue or ring group name anything you want, including a number. I assume what you don't want, is the callers number, displaying at the same time.
Unless you made a change to the incoming trunk settings (assuming this is a SIP trunk), to take caller ID from the "wrong" field, making it unavailable, then it is not possible. Of course, a change such as this, would affect all incoming calls, on that trunk.
Reactions: ChrisC_3CX
gmacinit
