- Joined
- Apr 9, 2021
- Messages
- 14
- Reaction score
- 1
Do not know if anyone can help.
I am setting up a Raspberry Pi with 3CX. I have set up trunks to Sipgate and added two extensions VVX411 and VVX300.All works fine.
Therefore the next step was to connect the PSTN line via the HT503,
The HT503 has firmware is Program -- 1.0.16.2 Bootloader -- 1.0.0.18 Core -- 1.0.16.1 Base -- 1.0.16.2 Extra -- 1.0.16.1 CPE -- 0.0.1.97
and I followed the following forum post.
However I just can not get it to work.
I have a "new" extension showing that I was not expecting
The SIP trunk is not registered
and the port status on the HT503 of the FXO is busy and not registered.
Could anyone provide any guidance or help. I am a bit stuck and running out of ideas.
Would anyone have some screenshots of how they would set this up.
POST - With info that I followed
Please follow this steps for HT503:
- Upgrade the HT503 to f/w 1.0.4.100
- Reset the device to factory default
- Make sure you use a fixed IP-address for the HT503
- HT503 and 3CX PBX must be on the same LAN
- Setup in “Basic Settings” the right Time Zone
- Setup in “Advanced Settings” the right Call Progress Tones
- De-activate FXS port
- Setup in “FXO Port” your country settings and…
FXO Termination
- Number of Rings: 2
- PSTN Ring Thru FXS: No
- PSTN Ring Thru Delay (sec): 1
Channel Dialing
- Wait for Dial-Tone: No
- Stage Method (1/2): 1
Now in 3CX please follow next steps:
- Create an extension/IVR
- Create Generic PSTN Gateway
- Gateway IP-adres: <HT503>
- Gateway Port: 5062
- During creation, setup Inbound Route to previous created ext/IVR
- Copy SIP ID, Auth ID and Password to HT503 FXO (type in, do not copy/paste!!!!)
Now setup “Basic Settings” HT503
- Unconditional Call Forward to VOIP: <previous created ext/IVR>@<Local IP PBX>:5060
Check if HT503 is registered
FXO Termination
Channel Dialing
