Rebooting server breaks SIP registeration and IVR to CallFlow
SalC
Hello, Using latest 16.0.910 on Debian.
Having an issue when i want to reboot the server. I login to SSH and do a reboot. The server comes back up fine with all the services running. However, the SIP trunk says it's registered (with no new register date) but the incoming line will ring busy. Also, the IVR extension i have set to transfter to a call flow just keeps ringing, even though other parts of the IVR work, it just doesn't send to call flow.
To fix this, I have to ssh in and run 3CXStopServices and then 3CXStartService. This seams to work around the issue. I hope it says stable.
Please advise! Thanks
You could make a bash script that has the commands:
3CXStopServices
3CXStartService
and make a cron job that runs that on reboot
I think the issue may have to do with a bug in the datetime of the system... I've noticed that after reboot, the initial services startup with the system time in the future even though the server and 3cx timezone is eastern. By stopping and then starting the services again, the time is correct.... this must be a bug somehow...
Wecare_ITA
