Solved Receive internal calls during DND
bytesolutions
Goodmorning everyone.
I have a configuration with five extensions, each with different office hours, therefore configured differently for each extension.
When the office is open the extension status is "available" and rings with external and internal calls, when the office is closed it is automatically set to DND and does not ring for any calls.
I need to make the phone ring only for internal calls also in DND. I tried to flag "Accept calls from Ring Groups" section but it doesn't work.
Is there a way to solve this problem of mine?
Thank you all
You cannot receive external calls when set to DND.
Therefore, you should change your routing for out of hours (closed) to go elsewhere rather then set your status to DND.
Thank you for your answer.
I tried to change status to "Away" or "Lunch" but no one profile allows me to block only external calls and to ring internal calls. They blocks all calls
I should have said "you cannot receive any calls when in any other status apart from Available"
Reactions: VasilisV_3CX
Feel free to post a new thread if you need further assistance or information @byte3.
Rich Hopkins
