Receptionist Role and Multi-Company Mode
Antoine Vella
Good Evening
Can Someone please guide me on how to set the receptionist role and the multi-company mode?
I can't seem to find any documentation about the functions.
Thanks in advance
Antoine
The information you are looking for can be found here:https://www.3cx.com/blog/releases/v18-update-4/, available on non-multi company mode-enabled systems. Also, note that when enabled, the multi-company mode is only for testing as it is a beta release. It's not for production systems, and when enabled, it will affect how extensions relate to each other regarding group rights. It is, therefore, best to set up a startup version:https://www.3cx.com/startup/
thanks a lot for your reply. So for the receptionist, is there actually a role to set or a box to tick? or anyone can use the receptionist view in the web portal? Thanks
you can find it under the users rights.
And under Groups you can define the Receptionist rights too.
Reactions: JosIPVG
WinSip
