Solved "Registering" extensions without logging in
Milos Boksan
Gold Partner
Heya all,
one of our customers just switched from a different PBX solution to 3CX.
They were used to having two sets of extensions previously, one for their deskphones in offices, and the others for mobile phones used by drivers.
For example 800-880 are office extensions, and 500-550 are those mobile extensions.
I want to replicate this in 3CX as close as possible so they can start using it while retaining their old habits and while they remember the numbers.
I created 50ish extensions that aren't ever going to be logged into, only for the purpose of forwarding any calls that come to those extensions to appropriate GSM numbers of drivers.
The only roadblock I ran into is that the newly created extensions are all "Unregistered" upon creation. And without logging into an account associated with the extensions and clicking the bell icon, I cant register them.
Is there any way to spare me from setting 50 passwords, and logging in 50 times, and clicling 50 bell icons? Can I "register" these extensions somehow from the Admin panel?
Thanks for the responses in advance.
Cheers
Enable this
You can also use the "Impersonate User" option from Admin > Users
The "ring my mobile" option worked like a charm.
Thank you my good sir.
Also nice little tidbit I didnt know about that you can impersonate a user. Very useful. 5 stars for this man (applause)!
Admins,
This can be marked as solved!
