Remote Backup not set?
SOTASOTA
SOHO User
I have this error message coming up in my Dashboard:
Remote storage is not configured. It is required to keep your system performant and easily updatable. Set Up Remote Storage
However, in the manual (https://www.3cx.com/docs/manual/backup/) is says:
To use the “Local disk” just disable Remote Data Storage & Archive and set the directory in Backup → Settings.- browse to select a local backup path with appropriate filesystem permissions.
But there is no area when I can set this!
3CX seems to be handing the backups just fine, and storing it locally at 3CX.
Stuck in a loop!!
Help!
The Remote Data Storage & Archive is already disabled:
I setup Remote Storage but the banner is still there!
Remote storage is partially configured. It is required to keep your system performant and easily updatable. Set Up Remote Storage
See a later post in that thread:
Reactions: KyriacosS_3CX
Thanks! Ticked all the boxes...working now. Cheers! Russ :)
Reactions: SteveITS
arming
