Remotely access on 3cx server
cbt.desk
I installed the new v16 but I can't access my account or 3cx server remotely on win 10 I did try disable the firewall but still getting same error and when the firewall was working I did try to change forwarding rule to port number
To login in the Management Console try:
https://<FQDN>:5001/
After the forward slash I must put the IP address of my server or domain name server?
No problem at all, just easier to know exactly what you use, but you're free not answering.
you are asking to solve problem not me :p ;)
if you try from same lan as PBX , you can try with local pbx ip followed by :5000
or https:// fqdn:5001 (if you set this port during install, otherwise this is 443) but in that case this only https://FQDN
You also can try with Public IP, guessing you have a static one.
same error
which one ?
Can u inbox me private I wwill forward the solution once the problem is resolved
you're welcome to post here your fix if something needs to be
Is it possible we can arrange remote assistance via anydesk remote
if you want PM me your FQDN, just to see if I can reach your login page, no need your credentials
