Remove microphone check.
net-products
Is there a way to remove the test for a microphone when accessing an extension via the webUI?
The check stops you from being even able to dial, which can be useful to test if things aren't working. It can be annoying if for example you're standing in a data center with just a screen and keyboard and you now have to emulate a microphone.
If I don't need to send any audio and only check the connection or receive audio, there technically is no need to have a microphone. My suggestion is to turn that popup into a warning message and just send silence if the user wants to continue. Or at least for there to be an option in the UI (if it doesn't already exist).
was is it youre trying to test for? Is it something the mobile app can do?
arming
