Solved Renewal for SSL Certificate for <fqdn> failed
it@agel
Receiving this error for 3 days in a row now:
HTTPS Certificate renewal Failed - Error:
IpUpdater.FqdnGenerationException: Error creating FQDN: FQDN generation for this key is in progress. Please try later.
at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort, Boolean isPassiveFailoverMode)
at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
Sometimes there is a communication problem between DNS Servers and LetsEncrypt which results in this exception. This happens rarely. In most cases, the second attempt will work. 3CX PBX will try again.
I checked all the settings like internet connectivity and DNS resolving from the PBX, all working okay. Where should I start looking?
I am seeing this across all of our PBX's for the last 2 days, did you get anywhere with it ?
Do you have a 3CX FQDN aswell? If so, I might guess the error occurs on their (3CX) Lets Encrypt services.
Same issue here.
as the email also stated that it is not a fatal issue and will be retried tomorrow.
Maybe something occurred on Let's Encrypt site. Let us know tomorrow.
It has been occurring for the last few days, so i suspect it is an issue with the lets encrypt 3cx link.
After getting errors for 3 days in a row the LE certificate is successfully installed.
Reactions: JohnS_3CX
EMMEPICASA
