Renewing Third Party Certificate on 15.5
tadrosr
Hello - I'm running version 15.5 on Debian. My godaddy cert will expire in a couple of weeks, but I can't seem to figure out where to upload the new cert from.
Thanks in advance
this is the windows answer
https://www.3cx.com/docs/self-hosted-instances-ssh/
i'm not sure about debian but i'd imagine you would only need to find the path to the cert files and change them out.
i'm not sure what you mean by "upload the new cert from"
you'll have to use an app to generate a CSR (you can use openSSL at https://downloads.3cx.com/downloads/misc/csrgen.zip).
in linux you can use the openssl command to generate your CSR
in your godaddy portal you'll have to rekey the cert and paste the CSR into the portal. once they generate the cert then you'll be able to download it
as far as what to do from here once you have your certificate, i'm not too sure about debian. i've installed certs on various versions of linux but not with 3cx. perhaps someone else can add more detail here.
@Shawn - thanks for sharing. I already have my certificate (private and public keys). I just need to upload them to my 3cx server.
@Shawn - thanks i'll give it a shot.
Zexus
