Replace SIP Trunk
TitleRequired
We have a system (16.0.5.619) that shows an unsupported trunk.
Its a VoiceHost trunk (UK) which has not been added using the VoiceHost template.
My question is, if i remove it, and add it back using the template, will i need to recreate all the inbound rules, or if if i use the same trunk name, will it just link those rules to the named trunk.
I have exported the rules to a CSV, but it doesnt mention the trunk specifically as far as i can see.
Add the new trunk first, then add a new fake rule, this will create rules with the correct trunk number is 10001 and or 10002, 10001 being your old trunk and 10002 the new one. in the csv replace all 10001 with 10002, then import, all rules will now point the the correct new trunk. then remove the old one
Thank you, that makes a lot of sense, and explains what the ports column is in the CSV!
Wecare_ITA
