Report for users/extension last login date
Széphő Zrt.
Hi Everyone,
I need a report from 3CX, but I can't find the right one. I need the last login time of users or extensions from the last 6 months. Is there a way to get it? For me, it's not whether a call was made, but when they last logged in? Whether in the application or on the web interface.
Additional information is that I updated to v20 U6 on August 4th.
Thanks for the help!
Hi, from dashboard you can click on the Active Connections button
Then use the filter with a custom date
Reactions: Széphő Zrt.
That will only show you the information about the connections using the web client /pwa, that is the closest report you may get about it, note if you were in v18 and just updated to v20 then you will not see anything there....
VOIPEric
